O
OctavioOlguin
Hi!. I'm consistently doing this to get a dataset from the appserver: 1) define Business Entity. 2) put BE on appserver 3) on client call a .p routine on appserver, wich in turn instantiates BE makes the Readxxx() call to the BE, and that's it. USING dw.dwTicketD FROM PROPATH. {dw\dwticketd.i} DEFINE INPUT PARAMETER pTicket AS INTEGER NO-UNDO. DEFINE OUTPUT PARAMETER DATASET FOR dsdwTicketD. DEFINE VARIABLE myTicketD AS dwTicketD NO-UNDO. /* ************* Main Block ************** */ myTicketD = NEW dwTicketD(). myTicketd:ReaddwTicketD(SUBSTITUTE("dwTicket.Ticket = &1", pTicket), OUTPUT dataset dsdwTicketD). I wonder is this the best practice? Should I instead be calling the class across the web? Is it posible?
