Forum Post: Re: Working With Mqseries (4gl)
  • Thread starter Thread starter Garry Hall
Garry Hall
You have to determine the offset and length for each field of MQOD you are trying to set, then use the appropriate PUT-* function to write it. I don't have the MQ include files to figure this out, but Google gave me a little help. MCHAR4 is a 4-byte datatype (char[4]). MQLONG is a 4 byte integer. If you wanted to set StrucId to "ODbb" and Version to 1, you would do the following: PUT-STRING(ObjDesc,1) = "ODbb". /* StrucId is at offset 0 */ PUT-LONG(ObjDesc, 5) = 1. /* Version starts at offset 4, because StrucId is 4 bytes */ For historical reasons, OpenEdge MEMPTR offsets are 1-based, not 0-based. This might also require an understanding of datatype alignment, and possibly an endianness considerations of the API. Once you start calling DLLs, you have to do a lot of the heavy lifting yourself.
