Forum Post: Re: [technical Users - Oe General] Re: [technical Users - Oe General]...
  • Thread starter Thread starter Mark Davies
Mark Davies
Hi, Another good idea would be to add a PROCESS EVENTS just after you set the wait state - that will give the client time to change its UI before going into the WHILE loop. -------- Original Message -------- > From: "beefhealy" > Sent: Monday, September 21, 2015 1:43 PM > To: TU.OE.General@community.progress.com > Subject: RE: [Technical Users - OE General] re: [Technical Users - OE General] SESSION:SET-WAIT-STATE has no effect > > Update from Progress Community [https://community.progress.com/] > > beefhealy [https://community.progress.com/members/beefhealy] > > Hi Mark, > > I used that code initially and it has the same problem. I used the custom cursor to rule out an issue with the default cursor. Thanks. > > View online [https://community.progress.com/community_groups/openedge_general/f/26/p/203 01/71901#71901] > > You received this notification because you subscribed to the forum. To unsubscribe from only this thread, go here [https://community.progress.com/community_groups/openedge_general/f/26/t/203 01/mute]. > > Flag [https://community.progress.com/community_groups/openedge_general/f/26/p/203 01/71901?AbuseContentId=914d2d8d-aa55-46e3-84a5-4634df8a1426&AbuseContentTyp eId=f586769b-0822-468a-b7f3-a94d480ed9b0&AbuseFlag=true] this post as spam/abuse.
