Forum Post: Re: Rollbase Oe Database On Other Machine
  • Thread starter Thread starter Karthikeyan Bhaskaran
K
Hi Jorrit, Thanks. If you have obtained a Rollbase Private Cloud license already, you may perform the installation as follows: Identify the machines as Rollbase machine or OpenEdge machine based on the hostname listed in the license file. Rollbase should be installed on the machine as per the hostname listed in your license file. Make sure the port number is also as mentioned in the license file. Install Rollbase on this machine, choose "Other Database" on the machine Run the installer on the database machine and finish the installation. The purpose here is to only install the database. (Rollbase will still be installed but you may choose to not use it). Then follow the documentation to configure the databases.xml file to point to the database. [ http://documentation.progress.com/output/Rollbase/index.html#page/rb/edit-databases.xml.html#wwconnect_header ] If you do not have a license now, step1 is not relevant. License can then be obtained for the machine running Rollbase. Hope this helps. (I have not tried this approach, but this should work). Regards, Karthikeyan
