Rob Fitzpatrick
The high number of stat calls for non-existent files sounds like propath searching. It could be normal for your application. It would be helpful to compare those numbers against prod, or a prod-like environment. Can you see the file names in your trace? If so, is it a lot of files with .p or .r extensions?
