Forum Post: Re: Open Edge 11.3 Disconnect Login
  • Thread starter Thread starter Libor Laubacher
L
Libor Laubacher
Steve, the code you can use is here: community.progress.com/.../30693 You would need to replace SYSPROGRESS there with the username you wish to disconnect and then use client (prowin32/_progres to run it while being connect to the database and being on machine where db is). /LL
