agent_008_nl
Hi Edsel, I still do not have it working. The generated error is the same: somebeforebufferhandle:error = true. somebeforebufferhandle:error-string = "Orderstatus is verplicht". The output I get with the function copied below the output: The function I use: function saveChanges(action, dataArrayId) { var jsdo = dataModel.jsdo; jsdo.subscribe('AfterSaveChanges', function callback(jsdo, success, request) { jsdo.unsubscribe('AfterSaveChanges', callback, jsdo); if (success) { var dataReturned = []; jQuery.each(request.jsrecords, function(i, value ) { dataReturned.push(value.data); dataReturned ._idBefore = dataArrayId; }); eventManager.fireEvent(action + "-data", function(listener){ listener.listenerFunction(dataReturned); // jsdo.getData() }); } else { console.log(request.response[Object.keys(request.response)[0]]["prods:errors"]); jQuery.each(request.jsrecords, function(i, jsrecord) { console.log(jsrecord); console.log(jsrecord.getErrorString()); }); } }, jsdo); try{ jsdo.saveChanges(true); // true - use submit } catch (e) { console.log("Error executing function in dataModel.updateData: saveChanges, exception: " + e.message); } } When I use the latest jsdo from https://github.com/CloudDataObject/JSDO (download today) I get the following exception: saveChanges requires CREATE, UPDATE and DELETE operations to be defined. while saveChanges is called with param true?! Any idea what goes wrong? Thanks, Stefan.
