Forum Post: Re: Issue Migrating To Telerik
E
egarcia
Hello Nitharshan, The error "Failed to load resource: the server responded with a status of 0" may indicate network connectivity issues with the backend or a CORS issue. Do you see more details on this error in the JavaScript Console if you do Inspect Element? What web browser are you using when you see this error? What is the resource that is being accessed? The Network tab would show the info the request. Can you access the data directly from the web browser by entering the URL of the resource? Here is an example on how the URL looks like to access the data: oemobiledemo.progress.com/.../dsCustomer Regarding opening the HTML file in the Telerik screen designer. (Just to avoid confusion of terms, I am using "screen designer" instead of "Screen Builder" because Telerik Platform also has a project type for mobile called Telerik Screen Builder where screens (views) are created using a wizard.) The migration from Rollbase Mobile App Builder to Telerik Platform uses the same HTML/JS/CSS from Rollbase Mobile, it does not convert the code to use Kendo UI components and as such the project cannot be open in the designer. Please reply with more details on the error loading a resource. I hope this helps, Edsel
