Forum Post: Re: Instantiated Class, Propagates Database Connection Need
O
OctavioOlguin
I came to this technique, that is the answer to my own question (sorry for bad english): I found that procedure that was calling appserver fired 3 to 4 procedures inside appserver, each doing connect/disconnect I noticed in broket server's log that appsever made 3 to 4 connections to db in as few as 2 to 3 seconds. I had the callings to appserver's routine, enclosed on CREATE hServer. hServer:CONNECT(serversConn). RUN xyz on hServer... /* this is the routine enclosed... */ hServer:DISCONNECT. DELETE OBJECT hServer. . . . . CREATE ... hServer:CONNECT.... RUN abc..... .. DELETE ... /*and so on*/ All I have to do was to transform several connections to only one: CREATE SERVER hServer. hServer:CONNECT (CadenaServer) NO-ERROR. RUN func/ConnectDB.p(dbName) on hServer. RUN xyz ON hServer. RUN abc ON hServer. run func/DisconnectDB(dbName) on hServer. hServer:DISCONNECT (). DELETE OBJECT hServer. Doing that, I accomplished: 1) Making one connection to db only for a lapse of time. 2) procedures xyz and abc were able to do it's stuff directly, even they had instances of classes that accessed database. Before that, I had to call xyz which connected to db and in turn called process_xyz , which made the stuff actually. That's what I meant by trick on my original question... Thanks everyone for interest on this thread. (posted for newbies (like me) looking for insight knowledge)
