Alex Hart
Thomas did you see if the generate-uuid generated duplicates as well? It is most likely that the way the "random" GUID is generated that is at fault even before encoding is done. I had to write something in the mainframe world as we did not have standard libraries to create GUID's and some of the suggested "random" methods did not work at all.
