James Palmer
If you're not using it for DR then I'd say that Pro2 is definitely worth considering as a solution. One of the really nice advantages of Pro2 is that your schema on the target can be different. So you can have production oriented indexes on production, and reporting indexes on the target. So you can really tune up each database for the application it is designed for. You can't do that with OE Repl.
