Forum Post: Re: Ccs Specs
  • Thread starter Thread starter agent_008_nl
agent_008_nl
blog.xebia.com/.../ "Micro services on light weight containers like Docker or maybe Dropwizard or Spring Boot are the end of the application server that served us so well last decade. If you can scale your application by starting a new process on a fresh VM you don’t need complex software to share resources. That means you don’t really need a lot of infrastructure. You can deploy small components with negligible overhead. Key-value data stores allow you to relax constraints on data that where imposed by relational databases. A service might support two versions of an interface at the same time."
