Forum Post: RE: Batching
E
egarcia
Hello, I would generally apply batching (paging) to a List control rather than to a Select control. For a List control in JQuery (the Mobile App Builder uses JQuery / JQuery Mobile), you could apply the concept of infinite scrolling, where the scroll event is detected and using some logic based on the scrollHeight attribute, the code loads additional data dynamically. I do not know if the scroll event applies to a Select control. I did some few internet searches via DuckDuckGo and found some links that can give you some ideas on this: - www.webdeveloperjuice.com/.../create-infinte-scroll-effect-using-jquery-with-demo - www.webdeveloperjuice.com/.../infinite_scroll.php - www.jplugins.net/kinetic www.jplugins.net/overscroll I have not tried them from the Mobile App Builder. I hope this helps.
