C
cverbiest
Hi Thomas, I think there are two types of mail for release/import/... targets. One is a mail with the build result, this shows the logging of the job , the other is a mail with the result of the job i.e. a release report, an import table report, ... The intended audience for both mails is different. The first mails is for the person who automates/monitors the process. If you use jenkins to run the jobs you can consult the build logging and will probably not need that in a mail. The second is for the developers/product managers using the system, they will want to know which tasks/objects got released/imported/... I think it's better to have 2 types of mail which can be turned on/off individually.
