Simon L. Prinsloo
My previous postI was wrong. The assignment in the following part of your code is of no meaning, as the variable is immediately overwritten with the output of DoWork(): hdlEntity = DATASET dsEntity:HANDLE. DoWork(OUTPUT hdlEntity). This means that the handle may point to a another dataset from the one you defined and the dynamic code is the only safe option. On the other hand, if you use an "OUTPUT DATASET dsEntity" parameter, as suggested by Mike, my previous post will apply.
