DivyaTheja
Hi Willer, Thanks for the feedback. We will take this as enhancement. For now, adding all the tests to a testsuite can reduce taking long time for execution since it uses a single AVM. For the second case where tests with same name are available in different folders: As per my knowledge, currently with ABLUnit ant batchtest, we can't provide the outfile pattern. I can see only two alternatives for this. 1. Adding tests with same name in test tag might help. test name="${basedir}/Case1/test1.cls" todir="${basedir}/Results" outfile="${user.name}-test.xml"/ batchtest todir="${basedir}/Results" format="xml" fileset dir="${basedir}" include name="**/*.cls" / /fileset /batchtest 2. Adding those tests in a single testsuite. Hope this helps, DivyaTheja
