Forum Post: Is There A Way To Stop Rollbase From Forcing "column" Names Into All Capital...
  • Thread starter Thread starter jsniemi79
jsniemi79
I'm trying to use the external objects, with data direct cloud, to access a SQL Server database. I have successfully set up the connection to the database. When I create my object and map everything, I don't have an option to change the column names that Rollbase is using on my view. It takes all of the columns and capitalizes them, but I get the following error when accessing the object tab. If I go to the data direct SQL tester and use the same code, I get the same error. However, if I update the KEYID field to KeyID, it gives me the correct result. Any help is greatly appreciated.
