O
OctavioOlguin
used to have: USING procs.ventas.dsCasoDetalle FROM PROPATH. {procs\ventas\inc\dscasoDetalle.i} DEFINE INPUT PARAMETER pControl AS DECIMAL NO-UNDO. DEFINE OUTPUT PARAMETER DATASET FOR dsCasoPaqDetalle. DEFINE VARIABLE myCaso AS dsCasoDetalle NO-UNDO. myCaso = NEW dsCasoDetalle(). myCaso:ReaddsCasoDetalle('control# = ' + string(pControl) , OUTPUT DATASET dsCasoPaqDetalle). DELETE OBJECT myCaso. and get on dataset some records to comply with control# = 50.3453 for instance... but today cleaned Project and updated. and can't get to work that readdsCasoDetalle call. I put a for each ttCasoPaqDetalle. message tt...fields. end. after the call and the dataset came empty. thiis is dscasoDetalle.i, I wonder if the primary key having fecha as part of pk, has something related to this. (I guess it is what changed from previous verions, but I'm not sure about it) DEFINE TEMP-TABLE ttCasoPaqDetalle BEFORE-TABLE bttCasoPaqDetalle FIELD Control# AS DECIMAL INITIAL "0" FIELD Fecha AS DATETIME FIELD Usuario AS CHARACTER FIELD Observacion AS CHARACTER INDEX ControlFecha IS PRIMARY UNIQUE Control# ASCENDING Fecha ASCENDING . DEFINE DATASET dsCasoPaqDetalle FOR ttCasoPaqDetalle. ... Any help would be appreciated. Thanks.
