Forum Post: Endeavor To "mobilise" Procedures From Appserver To Pas, To Telerik..
O
OctavioOlguin
Hi you al! I'm in the quest to get mobile some procedures, but I found myself into something I can't quite resolve.. Have the following calling procedure. ASSIGN FRAME {&FRAME-NAME} fFecha fFEcha-2 . CREATE SERVER hServer. GET-KEY-VALUE SECTION "CONNECTION" KEY "AppServerSuc" VALUE charID. lRetOK = hServer:CONNECT (charID) NO-ERROR. IF NOT lRetOK THEN DO: MESSAGE "..." VIEW-AS ALERT-BOX ERROR. RETURN. END. ELSE DO: {procs\inc\wait.i} RUN dw/GetAperturas.p ON hServer (fFecha, fFEcha-2, OUTPUT DATASET dsApertura ) NO-ERROR. END. hServer:DISCONNECT (). DELETE OBJECT hServer. EMPTY TEMP-TABLE scrApertura. FOR EACH ttApertura: CREATE scrApertura. ASSIGN scrApertura.Sucursal = ttApertura.Sucursal .... END. {&OPEN-BROWSERS-IN-QUERY-DEFAULT-FRAME} Then on appserver I have this called procedure (GetAperturas.p) {"DW\dwapertura.i"} DEFINE INPUT PARAMETER pFecha1 AS DATE NO-UNDO. DEFINE INPUT PARAMETER pFecha2 AS DATE NO-UNDO. DEFINE OUTPUT PARAMETER DATASET FOR dsApertura. DEFINE VARIABLE FechaCorriente AS DATE NO-UNDO. /* *************************** Main Block *************************** */ ASSIGN FechaCorriente = pFecha1. DO WHILE FechaCorriente <= pFecha2: FOR EACH dwh.Sucursal WHERE Sucursal.EnLinea NO-LOCK: IF ..... FOR EACH Apertura NO-LOCK WHERE Apertura.Sucursal = Sucursal.Sucursal AND Apertura.Fecha = FechaCorriente: CREATE ttApertura. BUFFER-COPY Apertura TO ttApertura. END. END. ELSE DO: CREATE ttApertura. ASSIGN ....... END. END. ASSIGN FechaCorriente = FechaCorriente + 1. END. My problem came at the point where the procedure has parameters, I woul like to use that same procedure to expose as rest for using with jsdo and stuff... and remote proc at PAS... Am I getting it right? or Am I confused about the possibilities on the technology involved? and should have 2 parallel procedures?
