Forum Post: Autoedge|thefactory Mobile Sample Application
  • Thread starter Thread starter EmilioFerrera
E
EmilioFerrera
Hi, I try to configure "AutoEdge|TheFactory Mobile Sample Application" within the Developer Studio 11.5 Evaluation. In the page: documentation.progress.com/.../ Adding the OE Web Server to PDSOE Follow the steps to add the OE Web Server to PDSOE: 1. In PDSOE, change the view to Servers view by selecting Window > Show View > Servers from the main menu. 2. In the Servers view tab, right-click anywhere in the tab and select New > Server. 3. In the New Server wizard that opens, select the OE Web Server that you want to add and click Next. 4. Select the default OE Web Server, restmgr1 and click Next. 5. In the Add and Remove page that appears, add the SecurityTokenService and VehicleOrService to the OE Web Server using the Add button. 6. Click Finish. To be able to add servers, ensure that you can connect to the OE Explorer using the credentials for web-based OpenEdge Management or Explorer ( http://localhost:9090/) . The default credentials for accessing OpenEdge Management or Explorer are Username: admin and password: admin. In Section 5, I can not locate services SecurityTokenService and VehicleOrService. what can I do? Thanks a lot
