V
Vimalkumar Selvaraj
Many spreadsheet and business intelligence (BI) applications support pivot tables or grids to make it easy for end-users to visualize multidimensional data. You can provide similar functionality in a Rollbase application with the Kendo PivotGrid widget. The PivotGrid widget gives users the ability to display cross-tabular data in the way they choose to visualize it We developed sample application in Rollbase that demonstrates how to use Pivot Grid with Rollbase objects. Please use attached sample app.xml. After installation kindly look at "Introduction and Instructions" tabs to understand how this sample app works and how to use. Generate sample data and exercise functionality as described in the ""Introduction and Instructions"" tab. The generated data is more realistic if your tenant has more than one User record. If necessary, you should add User records manually before generating the test data. I hope this helps. Thanks,Vimal
