I've created a program that creates a workbook and then populates data onto
two sheets of the workbook. Thought everything was fine and then I noticed
that if you run the program for a larger date range everything appears fine
but when you close Excel it still shows up in the programs listed under
CTRL-ALT-DEL. Other programs start going into "Not responding" mode.
I just went over the proper way to release the com-handles (between sheets
to avoid the "Illegal Operation" error message) so I don't think it's that.
Why the difference between a small amount of data (250 lines) vs. a large
amount of data (1100 lines)?
Win 98/Progress 8.2C/Excel 97
Thanks,
David Hopper
Lowen Corporation
Thanks,
David Hopper
Lowen Corporation
