Connection through Progress
I'm trying to connect to a host using the CONNECT command in Progress, but it's returning a connection failure, but when trying to do it through Postman, the sending is done correctly. Could someone tell me what is missing to connect through Progress?
Below is the code I ran to make the CONNECT:
DEFINE VARIABLE hSocket123 AS HANDLE NO-UNDO.
DEFINE VARIABLE cConnectionURL AS CHARACTER NO-UNDO.
cConnectionURL = "-H ":U + "7d8p6n4c7b.execute-api.us-east-1.amazonaws.com" + " -S ":U + STRING(80).
CREATE SOCKET hSocket123.
hSocket123:CONNECT(cConnectionURL) NO-ERROR.
MESSAGE hSocket123:CONNECT(cConnectionURL)
VIEW-AS ALERT-BOX INFORMATION BUTTONS OK.
Attached is the informacao.xml file, which I successfully sent via Postman.
