P
progresscommunities@progr
Hi i installed the trial version in my pc and just wanted to have a quick app that was able to read from the database. but still i get errors connecting and i am unable to query the databse. could someone please hlpe me out? i dont know if the trial version will give you issues when connecting using ODBC, or if i am using wrong paramenters when buidling the connection string. Where do i find the port DSN... and the rest of the info to create connection string?
thanks
Brian
c# code
public static string GetODBCDriverName(string Database, string Version)
string ODBCDriverName = "";
RegistryKey registryKey = Registry.LocalMachine;
RegistryKey registrySubKey = registryKey.OpenSubKey(@"SOFTWARE\ODBC\ODBCINST.INI\");
String[] SubKeyNames = registrySubKey.GetSubKeyNames();
foreach (String KeyName in SubKeyNames){
if (KeyName.Contains(Database) && KeyName.Contains(Version)){
ODBCDriverName = KeyName;
break;
registrySubKey.Close();
registryKey.Close();
return ODBCDriverName;
then
using the following code to connect to the database
OdbcConnectionStringBuilder odbcConnectionStringBuilder = new OdbcConnectionStringBuilder();
OdbcCommand odbcCommand;
int RecordFound = 0;
odbcConnectionStringBuilder.Driver = GetODBCDriverName("Progress", "11.2");
if (odbcConnectionStringBuilder.Driver == "")
Console.WriteLine(" ODBC Driver is not installed");
return -1;
odbcConnectionStringBuilder.Add("DSN", "SPORTS");
//odbcConnectionStringBuilder.Add("UID", "no-user");
//odbcConnectionStringBuilder.Add("PWD", "no-pass");
odbcConnectionStringBuilder.Add("DB", @"C:\OpenEdge\WRK\Db2.db"); // copy of database SPORTS
odbcConnectionStringBuilder.Add("HOST", "mypcname");
odbcConnectionStringBuilder.Add("PORT", "5162"); // i found this port inn the log file
using (OdbcConnection connection = new OdbcConnection(odbcConnectionStringBuilder.ConnectionString))
connection.Open();
try
odbcCommand = new OdbcCommand("SELECT COUNT(*) FROM pub.Invoice WHERE Invoicenum > 0", connection);
odbcCommand.CommandTimeout = 1;
object executeScalarResult = odbcCommand.ExecuteScalar();
RecordFound = Convert.ToInt32(executeScalarResult);
catch (Exception e)
Console.WriteLine(e.Message);
thanks
Brian
c# code
break;
then
return -1;
connection.Open();
try
catch (Exception e)
