Hi Casper
In what release are they planning to do this? I heard of it a few times but never heard a specific version in which it is going to be released.
not something i was particularly waiting for
but heres an excerpt from Tom's post
<quote>
18) OE DB Roadmap -- This is about half looking back and reminding us
(or teasing those who are on older releases) and then Rich Banville gets
up and tells us what's coming. I'll skip the stuff we already have...
there were, of course, all sort of caveats but no shrink wrap NDA that
so here's what I scribbled:
10.1B (referred to as a "limits" release, primarily removing and
extending various limits & restrictions)
- Enable AI Online
- Table & Index IO by User VST !!!!!!!!!! Thank you, thank you, thank
you!!!!! Now how about "what program is the user running? and what
line? and what is the query string? ;-)
- Large keys (2000 byte indexes -- needed for unicode, not supported for
1k & 2k databases)
- Large shared memory
- 64 bit rowid, integer & sequences (plus a magic conversion from 32 bit
integers)
- 32,000 areas
- DataExtend integration
- Temp table database => 4k or 8k
- Adaptive transactions (not explained, back ported to 10.0b05)
- SQL query timeout
- SQL multi-db query
- SQL order-by, group-by
- SQL select-top
- SQL wide table support
Beyond 10.1B (on the roadmap but less clear on the details)
- Table partitions
- SQL/XML/Xquery
- Stats daemon
- Star Schema
- SQL multi-statement execution (*not* in parallel)
- Federated ID management
- Unified authorization management
- Column encryption
- SQL roles
- Secure utilities
- Referential integrity
- Alter -B, -L, -n etc online (probably upward only)
- Online index deactivation
- Self healing db
- Parallel server (*way* out there but finally on the radar!
ObjectStore influence?)
- Runtime SQL stats
- Transact SQL
- Multiblock IO (and larger blocks)
- More automatic tuning
- Increased concurrency
- Threaded utilities (at the "object" level -- aka threads per table or
index).
- "Snap Backup" certifications.
- Very Large Memory
- Big B by area or object (and possibly other appropriate parameters).
</quote>
(Same with gui and referential integrity).
not very soon. late 2007, very late 2007, or so i heard
i haven't seen the prototype demo at exchange and i dont know enough
about it.
but i hope it wont be too much of a hurried release and will have enough
basic functionality to make it useful.
if for example it wont have a resizing scheme, i believe, it will be another
traumatic experience for many of us.
an interesting aspect of it is that it opens the possibility in the future for
pda's and other devices.
sounds like theres alot of exciting work being done with user interfaces,
including ajax.
