noorienraza
DBCODEPAGE- iso8859-1
CPSTREAM CPTERM-ibm850
CPINTERNAL CHARSET - iso8859-1
Progress Ver 11.1 on unix .
When copying a file in utf format to longchar variable and converting to iso8859-1, special dutch characters are being converterd to junk characters. (e.g. umlaut).
COPY-LOB FROM FILE (ip-xml-tx) TO OBJECT lv-long CONVERT TARGET CODEPAGE "iso8859-1".
CREATE X-DOCUMENT lv-doc-hd.
lv-doc-hd:LOAD("longchar", lv-long, FALSE) .
lv-doc-hd is then used to populate a dataset and validate/update the database.
I tried giving SOURCE CODEPAGE "utf-8" and it seems to work. But the real issue i have is that this xml file is received from Sonic ESB in utf and there seems to be only one function "getLongTextCP" that allows code page conversion to a target codepage and cannot specify source codepage any where. So on using this function "getLongTextCP" and then reading the data in the dataset, the dataset contains junk characters.
Thanks
Thanks
