Can any1 help me with using Progress 9D and NuVu Reporting Suite???
Ryan_sa
Hi my name is Ryan. Our company is thinking bout purchasing product called NuVu Reporting Suite to handle our reporting.
Currently reporting from our prog's using frames & forms to txt files. Very unattractive and messy.
NuVu takes data and displays it in a viewer, using a template. I have worked with PDFInclude before and I think it maybe some thing like that but not sure.
My question is how do I take data from progress and create a report using NuVu?
Any advice would be greatly appreciated.
Ryan
joey.jeremiah
ProgressTalk Moderator
Staff member
you can replicate (in real time) your progress database to sql server, mysql etc. which could make a world of difference in terms of the sql engine performance if you're using an old progress version (and even if you're not).
and then use any of the popular tools around, like, reporting services, birt (open source), even excel etc.
we did a similar project recently send me a private message if you'd like to talk. cheers.
