BIG Progress 9.1d Problem
I have a BIG problem.
I have a customer that is running on software with a PROGRESS database backend.
The application is using a table that has a column named 'SYSDATE'.
'SYSDATE' is also a PROGRESS RESERVED WORD so the use of it as a column name was a wonderful idea on the software manufactures side.
So my problem is if I write an insert or update statement I get a syntax error.
I need really really really need to update that fields value or I'm in trouble.
Example:
UPDATE PUB.PartTran SET SYSDATE = SYSDATE() WHERE (PartNum = '123-123-123')
=== SQL Exception 1 ===
SQLState=42000
ErrorCode=-20003
[JDBC Progress Driver]:Syntax error (7587)
Example:
SQLState=42000
ErrorCode=-20003
