Authentication Solution
rajaselvam26
Need Authentication Solution
Hi All,
Which is the best authentication method used in Progress?
Whether a LDAP or Token Based. And also give me some good links to get some samples for authentication codes.
ss_kiran
The attached document should be able to get you started.
Thanks
- Kiran
