Question 64bit/32bit cross-compatibility
Cringer
ProgressTalk.com Moderator
Staff member
In Openedge 11.3, I know the rcode is cross compatible between 32 and 64 bit platforms, but what about the .wrx files? Does anyone have any experience?
TomBascom
Curmudgeon
They don't work on UNIX. UNIX is a real OS that doesn't encourage embedding of viruses in application code ;)
RealHeavyDude
Well-Known Member
As far as I know: WRX files are containers for OCX controls. If the OCX controls are 32Bit ( like the ones for example used in Dynamics ) then you can't use them with a 64Bit Progress executable like the prowin.exe that comes with OE 11.3. You need to stay with the prowin32.exe. Maybe the WRX files themselves are not bit-sensitive but the embedded OCX controls are.
Heavy Regards, RealHeavyDude.
Cringer
Staff member
Thanks RHD. That could be an issue. We will have to find a way around it.
gareth.roberts
I've done some testing with this and you don't need to change your wrx files you just have to have the 64 bit version (assuming one exists) of the OCX registered.
