H
hikmetalemdaroglu@gmail.com
when i was run proutil command for idxbuild , i get an error . proenv>proutil master -C idxbuild all OpenEdge Release 11.6.4 as of Mon Oct 23 11:21:54 EDT 2017 Use "-cpinternal UTF-8" with idxbuild only with a UTF-8 database. (8557) Index rebuild did not complete successfully i wrote Article 000032161 and i see the definitions about utf-8 in startup.pf Here is the startup.pf #This is a placeholder startup.pf #You may put any global startup parameters you desire #in this file. They will be used by ALL Progress modules #including the client, server, utilities, etc. # #The file dlc/prolang/locale.pf provides examples of #settings for the different options that vary internationally. # #The directories under dlc/prolang contain examples of #startup.pf settings appropriate to each region. #For example, the file dlc/prolang/ger/german.pf shows #settings that might be used in Germany. #The file dlc/prolang/ger/geraus.pf gives example settings #for German-speaking Austrians. # #Copy the file that seems appropriate for your region or language #over this startup.pf. Edit the file to meet your needs. # # e.g. UNIX: cp /dlc/prolang/ger/geraus.pf /dlc/startup.pf # e.g. DOS, WINDOWS: copy \dlc\prolang\ger\geraus.pf \dlc\startup.pf # # You may want to include these same settings in /dlc/ade.pf. # #If the directory for your region or language does not exist in #dlc/prolang, please check that you have ordered AND installed the #International component. The International component provides #these directories and files. # -cpinternal UTF-8 -cpstream UTF-8 -cpcoll Basic -cpcase Basic -d dmy -numsep 44 -numdec 46 I'm tired of trying. please help me !! /Hikmet
