Validation Problem
jai shankar
hi to all,
I want to put a validation for database field so that it can only contain characters (a-z & A-Z & space).I don't know what's the process.
Any one can suggest me the solution.
Thanks in advance.
There are many ways. You first have to decide how you want to block the characters you don't want - as they are entered, when the user tabs out of the field, when the user clicks the "save" button, or at the back end in the data dictionary level, such as an assign trigger or a validate statement ...
Thakns Nabi
hi,
But I have implemented it useing API-Smart Data field options and i want to do validation using coding.Can U tell me any example code for that.
Example ques: Put the validation for name database field so that it only accept characters(a-z,A-z,'')?
Thnaks and Regards.
DEF VAR cChar AS CHAR.
DEF FRAME f cChar.
ON ANY-PRINTABLE OF cChar IN FRAME f
DO:
   IF NOT
	  DYNAMIC-FUNCTION('isAlphaNumeric':U,KEYFUNCTION(LASTKEY))
  THEN
	RETURN NO-APPLY.
END.
ENABLE cChar WITH FRAME f.
WAIT-FOR WINDOW-CLOSE OF CURRENT-WINDOW.
FUNCTION isAlphaNumeric RETURNS LOGICAL (INPUT ipcField AS CHARACTER):
	DEFINE VARIABLE cAcceptables AS CHARACTER
	INIT " ABCDEFGHIJKLMNOPQRSTUVWXYZ" NO-UNDO.
	DEFINE VARIABLE i			AS INTEGER		 NO-UNDO.
	DEFINE VARIABLE lBadChar	 AS LOGICAL		 NO-UNDO.
	DO i = 1 TO LENGTH(ipcField):
	   IF INDEX(cAcceptables,SUBSTRING(ipcField,i,1)) EQ 0 THEN
		  DO:
			 ASSIGN lBadChar = TRUE.
			 LEAVE.
		  END.
	END.
	RETURN IF lBadChar EQ TRUE THEN
			  FALSE
		   ELSE
			  TRUE.
END FUNCTION.
ON 'any-printable':U OF fill-in
DO:
   IF (KEYCODE(KEYLABEL(LASTKEY)) >= 97) AND (KEYCODE(KEYLABEL(LASTKEY)) <= 122)  THEN.
ELSE IF (KEYCODE(KEYLABEL(LASTKEY)) >= 65) AND (KEYCODE(KEYLABEL(LASTKEY)) <= 90) THEN.
ELSE
       RETURN NO-APPLY.
END.
