[stackoverflow] [progress Openedge Abl] Openedge 10.2a - Input Through Set Does Not Work...
  • Thread starter Thread starter aza
aza
We were using below code to get the name of the computer.
def new shared var cHost as char format "x(40)" no-undo.
INPUT THROUGH hostname NO-ECHO.
SET cHost.
INPUT CLOSE.
DISPLAY chost.
After we have updated our computers (Windows 10 - 1703), it no longer works. It seems SET cHost is the part where it fails. I have tried IMPORT UNFORMATTED cHost but it does not work.
PS: I can get computer name using OS-GETENV("COMPUTERNAME") but I have to do it using INPUT THROUGH statement.
Edit: It seems that it is not only a problem with 10.2A but a more general one. Also it is not just related to hostname but all console applications and ms-dos commands. Now I will try to replace INPUT THROUGH statement with another Progress command if there is any, or try to communicate with existing console applications with some other method.
