[Stackoverflow] [Progress OpenEdge ABL] Is it possible to provide estimate hrs or minutes for progress completion? - PROGRESS 4GL
  • Thread starter Thread starter Bharat
B
Bharat
I am using below query for progress completion which shows how much percentage is completed in record updating process. My question or doubt here is Is it possible to provide estimated hrs/minutes for this progress completion?
For example, consider a table has 1000 records and each record gets into some validations before updating and approx time is less than a second(milliseconds). So if a single record takes less than a millisecond to update after gets to validations then what will be estimated for 1000 records? How to calculate and convert into hh:mm:ss? Please help to write a sample query.
DEFINE VARIABLE I AS INTEGER NO-UNDO.
DEFINE VARIABLE iPercentage AS INTEGER NO-UNDO.
DEFINE VARIABLE iComp       AS INTEGER NO-UNDO.
DEFINE VARIABLE iRec        AS INTEGER NO-UNDO.
ASSIGN
I     = 0
iComp = 0
iRec  = 0
iPercentage = 0.
/* Calculating Total records*/
FOR EACH <table> NO-LOCK:
  iRec = iRec + 1.
END.
/* Taking each records from the same table to update*/
  I = I + 1.
  IF I = 1 THEN DO:
  /*do some more validations*/
    iComp =  iComp  + I.
    iPercentage  = 100 * (iComp / iRec).
    IF iPercentage = 100 THEN DO:
        MESSAGE "Record Updation Is completed".
    END.
    ELSE DO:
        I = 0
        NEXT.
    END.
 END.
 END.
