SQL Explorer problem
J.Raum
Hi there,
don't know if it is the right forum.
I have a question about SQL-Explorer:
If I try to define a trigger or a procedure using sqlexp I get an error ( error in compiling the stored procedure. ) from the jdbc driver.
I get this message even If I leave an empty body´. i.e.:
CREATE TRIGGER TR_test BEFORE INSERT ON TEST1 REFERENCING NEWROW
FOR EACH ROW
BEGIN
END
Does it depend on a incorrect configuration of our system, or is it my fault ?!
thanks in advance
