Hi,
I am new to Progress SQL Explorer. I have used Oracle's SQLPlus for years but need a bit of help getting started with SQLExplorer. I understand the SQL code and have can type in simple SQL commands and that is working fine.
My questions are:
Once you have typed in the SQL code and followed it by ; RETURN and run it, how do you list your code again? In SQLPlus, you typed l (lower case L).
How do you run it again?
How do you change a line of code?
I have the SQL92 Guide and reference but I cannot find the answers there. Is there another document that would help?
Thanks,
Mark
My questions are:
Thanks,
Mark
