Try hacking this for your own use.
You have to trap the keydown event in the ocx.
** I N C L U D E
** File: result/object/accel.i
** Author: Chris Paulson
** Date: 17-09-96
** Description: Code to pass activate window menu accelerators from within
** vbxs. Circumvents a known Progress bug.
define variable keymodifier as integer no-undo.
define temp-table t_accelerator no-undo
field accelerator as char
field h_menu-item as handle
index primary is primary unique
accelerator .
PROCEDURE BuildAccelerators :
define input parameter p_menu as handle no-undo.
define variable widget as widget-handle no-undo.
define variable butAcc as character no-undo.
/* MJGK - 9 January 1998 */
if p_menu:type = "BUTTON" then do:
assign butAcc = p_menu:label.
if index(butAcc, "&") <> 0 and
substring(butAcc, (index(butAcc, "&") + 1), 1) <> "&" then
assign butAcc = "ALT-" + substring(butAcc, (index(butAcc, "&") + 1), 1).
else
assign butAcc = "ALT-" + substring(butAcc, 1, 1).
if butAcc <> "ALT-" then do:
find t_accelerator exclusive-lock
where t_accelerator.accelerator = butAcc
NO-ERROR.
if not available ( t_accelerator ) then
do:
create t_accelerator.
assign t_accelerator.accelerator = butAcc.
end.
assign t_accelerator.h_menu-item = p_menu:handle.
end.
end.
else do:
assign widget = p_menu:first-child.
do while widget ne ?:
if widget:type = "SUB-MENU":u
then
run BuildAccelerators ( input widget ).
else
if can-query ( widget, "ACCELERATOR":u ) and
widget:ACCELERATOR ne ? then
do:
where t_accelerator.accelerator = widget:ACCELERATOR
NO-ERROR.
do:
assign t_accelerator.accelerator = widget:ACCELERATOR.
end.
assign t_accelerator.h_menu-item = widget:handle.
end.
assign widget = widget:next-sibling.
end.
end.
END PROCEDURE.
PROCEDURE CheckKeyAccelerator :
define input parameter nKeyCode as integer no-undo.
define input parameter nKeyShift as integer no-undo.
if keymodifier = 0 and ( nKeyShift > 0 or nKeyCode = 18 )
then
assign keymodifier = nKeyShift + 1.
else
do:
where t_accelerator.accelerator = (if keymodifier > 0
then entry ( keymodifier
, "ALT-,SHIFT-,CTRL-,,ALT-" )
else "":u )
+ (if nKeyCode < 112 or nKeyCode > 123
then keylabel ( nKeyCode )
else "F" + string ( nKeyCode - 111 ) )
NO-ERROR.
if available ( t_accelerator ) and
valid-handle ( t_accelerator.h_menu-item )
then
apply "choose":U to t_accelerator.h_menu-item.
assign keymodifier = 0.
end.
END PROCEDURE.
/****************************** END INCLUDE *************************************/
