Running .w from a dialog box
Shannon Adams
For an application main menu (w-main.w), I am using a dialog box with buttons. When the user clicks on a button, the following code fires:
current-window:sensitive = no.
run w-app1.w.
current-window:sensitive = yes
99% of the time, when the called application is exited, the main menu re-appears. However, sometimes the main menu remains in the task bar and the only way to get it to re-appear is to right-click and choose restore. This only happens when running Windows XP. I don't recall it every happening in Me/98/95. Any ideas? 9.1c character.
Thanks,
Shannon
Did you try WINDOW-STATE attribute and MOVE-TO-TOP method from window widget ? Works fine with GUI...
Hi,
I did it the following way and never had problems with it:
DEFINE VARIABLE yWINDOW   AS WIDGET-HANDLE NO-UNDO.
DEFINE VARIABLE lMyHidden AS LOGICAL       NO-UNDO.
yMyWindow = FRAME {&FRAME-NAME}:HANDLE.  /* Handle of dialog */
lMyHidden = FRAME {&FRAME-NAME}:hidden.  /* get hidden status  */
yMyWindow:hidden = yes.    /* Hide Dialog */
yMyWindow:visible = no.    /* make dialog invisible*/
run <Programm with Smart-Window>.
yMyWindow:hidden = lMyHidden.       /* unhide dialog*/
yMyWindow:visible = yes.   /* make dialog visible again */
Maybe this helps :)
Greetings
Mav
Hi Maviee,
Setting the HIDDEN attribute hides the widget and conversely setting the VISIBLE attribute views the widget, it's not the same thing.
For example, if you set a button attribute to HIDDEN = NO if the containing frame is HIDDEN = YES it still won't show up. But if you set VISIBLE = YES you would force the button to showup which will also make the frame VISIBLE.
That's all you need
<snippet>
</snippet>
There's a thorough explanation in the on-line felp (F1) and the documentation.
Shannon cross posted on PEG and I believe he already got an answer, but he didn't bother to tell us, remember that the next time he's desparate for help.
http://mail.google.com/mail/h/1x5xlq9ygohyq/?s=s&th=106ec23304df5514&v=c
