RequestBuilder Assistance
Andy Whitcombe
Morning All,
I am using RequestBuilder for the first time, and I coming across an error, which I am struggling to resolve.
Using the following code
    oClient = ClientBuilder:Build():Client.
    /* User Name, Password and Domain... we dont have these
    oServiceCredentials = NEW Credentials(ipServerURL, ipUserID, ipPassword).
    oRequestBody = NEW String(oRequest:GetJsonText()). /* The JSON AS A LONGCHAR*/
    oRequest = RequestBuilder:Post(SubmissionURL, oRequestBody) /* Submit Request TO URL, Payload is the JSON */
          :ContentType("application/json")
          :AddHeader("Authorization",SigningStringHMAC)
          :AddHeader("Indentation","2")
          :AddHeader("partnerId","XYZ")
          :AddHeader("Timestamp",SUBSTRING(ISO-DATE(SigningStringTimeStamp),1,23) + "Z")
          :AcceptJson()
          :Request.
    oResponse = oClient:Execute(oRequest).
    CATCH e AS Progress.Lang.Error :
      MESSAGE "APW DEBUG " STRING(TODAY) STRING(TIME,"HH:MM:SS") SKIP
      PROGRAM-NAME(1) SKIP
        DYNAMIC-FUNCTION("TranslateText","e:GetMessage(1)") e:GetMessage(1)
      VIEW-AS ALERT-BOX INFORMATION TITLE DYNAMIC-FUNCTION("TranslateText","APW DEBUG MESSAGE") .
    END CATCH.
I get the following error
e:GetMessage(1) Authorization header value must have at least 2 " "-delimited parts: ixQVrK2qH6bajs2ZeHxsJaoBwwjOgs0eHFBvwMwvFqE=
If I debug the component parts and post using Postman, I see a success.
Please notes the HMAC in the following screen shot is not the same, its from a test I did yesterday, so the calculated value is different
I am hoping people with more experience of RequestBuilder can spot something obvious.
Thanks.
Thanks @Stefan
If I compare to the c# code generated in postman for a valid request..
client.Timeout = -1;
var request = new RestRequest(Method.POST);
request.AddHeader("Content-Type", "text/plain");
request.AddHeader("Authorization", "if/gWccU84vKq6Uj1zUZqqWOnpIbIj/rs7i4UH/fZX4=");
request.AddHeader("partnerId", "XYZ");
request.AddHeader("Timestamp", "2021-06-18T10:03:32.258Z");
request.AddHeader("Indentation", "2");
I thought that what I was attempting to replicate
Working with another Dev, we considered looking at System.Net.Http.HttpClient which allows for adding headers without validation
DEFINE VARIABLE client AS System.Net.Http.HttpClient.
client:DefaultRequestHeaders:TryAddWithoutValidation("Authorization","if/gWccU84vKq6Uj1zUZqqWOnpIbIj/rs7i4UH/fZX4=").
Is there such an option in Openedge?
The HttpHeaderBuilder is registering headers named Authorization with the AuthorizationHeaderBuilder class, which invokes the AuthorizationHeader class which contains the check on the value. You may be able to override this registry entry with the DefaultHeaderBuilder, but I have no experience with this.
The hammer / screw approach (which always works) is to ensure you include your version of the AuthorizationHeader class with the check removed is found first in your propath.
