Progress Openedge 10.2A silent install Problems
Phil Malle
Hi,
I am new at these forum. So i wanted to say hi.
And i have a question about the silent install of the Openedge Shared Network installation of OpenEdge 10.2A.
Is there a soulution to run the setup silently?? I tried everything i know. With parameters from installshild.
But nothing worked.
I found a entry in the pscNetSetupMsg.log file:
Message=A path to the log file must be supplied using the -psclog parameter.
but i don't know what these mean.
Can anybody help me??
Thanks & Regards
Phil
Have you read the installation manual? It has a section on creating response files for silent installs. By the way if you can avoid it, I would recommend staying away from a network install. Performance will not be ideal.
The 10.2A installation manual is here.
HI,
I have read the installation manual, but nothing works. :(
I have tried with the response file.
In my case i will install the shared network installation on different clients, so i need a silent installation.
BR
PHil
