Jessica Malakian
Maintaining the health and performance of your Progress Application Server for OpenEdge (PAS for OpenEdge) environment is critical for keeping operations seamless. Our recent webinar covered best practices for monitoring PAS for OpenEdge, leveraging key tools and proactively managing system performance. Read on for a recap of the session’s key takeaways.
Monitoring PAS for OpenEdge effectively helps prevent performance bottlenecks, provides system stability and enhances user experience. Whether you’re troubleshooting an issue or optimizing resource allocation, having the right monitoring strategy in place can save you time and effort.
PAS for OpenEdge provides multiple monitoring tools, each with its unique advantages:
The PAS for OpenEdge REST API is a lightweight and efficient way to pull key metrics. It’s ideal for monitoring and alerting. Common use cases include:
By automating REST API calls, you can integrate PAS for OpenEdge health checks into your broader monitoring framework.
While PAS for OpenEdge requires additional setup and permissions, it’s an excellent choice for long-term performance monitoring and capacity planning.
Another powerful tool for gathering PAS for OpenEdge performance data, OEJMX offers some advantages over REST API:
The PAS for OpenEdge Health Scanner continuously assesses server availability, making it an essential feature for load-balanced environments. The scanner will keep a “health” score of the PAS for OpenEdge instance and machine. If the health falls below the threshold, a query of the health API will return a message to have the Load Balancer remove the PAS for OpenEdge instance. Key benefits of the scanner include:
Key Metrics to Monitor
Effective PAS for OpenEdge monitoring focuses on tracking the right metrics to detect anomalies before they become issues. Here are key metrics to keep an eye on:
Automating PAS for OpenEdge Monitoring for Proactive Management
Rather than reacting to problems as they arise, automation allows you to proactively manage PAS for OpenEdge health. The automation process includes:
Final Thoughts
PAS for OpenEdge monitoring doesn’t have to be complex. By leveraging the REST API, OEJMX and the Health Scanner, you can maintain high availability, optimize performance and minimize downtime.
If you missed the live webinar or want to dive deeper into PAS for OpenEdge monitoring strategies, we invite you to watch the full session on demand. Stay tuned for more insights and best practices in our upcoming sessions!
Watch the webinar now.
Why PAS for OpenEdge Monitoring Matters
Monitoring Options for PAS for OpenEdge
REST API for Real-Time Insights
- Checking session and agent counts
- Monitoring memory usage and response times
- Making several requests for metrics in a short time
OEJMX for Deep-Dive Analysis
Gathering several different metrics in one call
Collecting information on Tomcat
Health Scanner for Automated Health Checks
- Promoting high availability
- Warning of possible slowness or crash imminent
- Allows for easy trending of data with a ProDataSet output
- Availability: Confirm PAS for OpenEdge instances are running and responding to requests.
- Thread Pool Usage: Monitor the number of active and idle threads to prevent saturation.
- Session Counts: Keep track of active, queued and timed-out sessions.
- Memory Consumption: Identify potential memory leaks or excessive garbage collection.
- Overall System Health: Use built-in health checks to get a comprehensive view of PAS for OpenEdge stability.
- Setting up alerts based on REST API or OEJMX data
- Integrating monitoring with enterprise tools like Prometheus or Splunk
- Trend the data so you can watch for changes over time
Final Thoughts
