[progress Communities] [progress Openedge Abl] Wiki Page: How To Add A Custom Module And...
E
egarcia
Kendo UI Builder 2.0 introduces a new project structure. This project structure new has a scripts/extensions folder than can be used to add custom AngularJS modules (app/src/scripts/extensions). A service define in the custom folder can then be accessed from controller.public.js to provide access to custom code. Developers using Kendo UI Builder can use a custom module to create their own high level APIs to encapsulate code and re-use it from multiple views. Also, a high level API can be used to minimize the impact on migrating to new versions of Kendo UI Builder. The usage is of the functionality has three general steps: Add custom module and service to the scripts/extensions folder. Add the custom service to $inject. Example: Module1CustomerViewCtrl.$inject = ['$scope', '$injector', 'stateData', 'myService']; Add reference to constructor. Example: constructor($scope, $injector, stateData, myService) { Note: An alternative to use $inject and passing the service in the constructor is to access the service by calling: $injector.get(). Example: var myService = $injector.get('myService'); Steps The following steps show the configuration of the files involved on this configuration. See attachment for copy of a sample project containing the files. index.js (scripts/extensions): Add import and reference to custom module in the scripts/extensions/index.js file. 'use strict'; import angular from 'angular'; import myModule from './my-module.js'; export default angular.module('app.extensions.module', [ 'myModule' ]).name; my-module.js (scripts/extensions): Add import and registration of custom service in the module. Note: Service can also be defined in same .js file as module. 'user strict'; import myService from './my-service.js'; var myModule = angular.module('myModule', []); myModule.service('myService', myService); my-service.js (scripts/extensions): Service definition. Create service instance with methods for high-level API. This example shows APIs: getElement(), getDS() and createLookupColumn(). 'user strict'; function service() { function MyService() {} MyService.prototype = { getElement: function (controller, name) { return controller.$components[name]; }, getDS: function (controller, name, options) { if (controller.$ds[name]) { return controller.$ds[name]; } else { return new kendo.data.DataSource(options); } }, createLookupColumn: function (controller, grid, options) { var columns, i, column; // Find column if (controller.$components && controller.$components[grid]) { columns = controller.$components[grid].options.columns; } else { columns = controller.$model.options.columns; } if (columns) { for (i = 0; i " } else { return " " + kendo.htmlEncode(view[0][options.displayField]) + " "; } }; column.editor = function(container, options1) { var input = $(" "); input.attr("name", options1.field); // Clear filter to ensure that all values are shown options.dataSource.filter({}); input.appendTo(container); input.kendoDropDownList({ dataSource: options.dataSource, dataTextField: options.displayField, dataValueField: options.field, }) }; } } }; return new MyService(); } export default service; controller.public.js (module/view folder): This screenshot shows the usage of the custom service "myService" from within the constructor in controller.public.js. The code obtains a data source associated with the view and creates a "lookup" column. The implementation of the service then executes the appropriate code to set the template and editor properties for the corresponding column in the grid. import BaseController from './controller.js' class Module1CustomerViewCtrl extends BaseController { constructor($scope, $injector, stateData, myService) { super($scope, $injector); var controller = this, salesrepDS = myService.getDS(controller, 'SalesrepDS'); salesrepDS.read(); myService.createLookupColumn(controller, 'grid0', { dataSource: salesrepDS, field: 'SalesRep', displayField: 'RepName' }); } // Fired when custom html section is loaded includeContentLoaded() { } // Fired when custom html section loading failed includeContentError(e) { } // Fired when view content is loaded onShow($scope) { } } Module1CustomerViewCtrl.$inject = ['$scope', '$injector', 'stateData', 'myService']; export default Module1CustomerViewCtrl
