Dhyani
Hello friends, I need your help in one of the issue we are facing with Jenkins. I am getting my Build Failed with error ( You must not specify more than one attribute when using refid ) in the Console Output on Jenkins. Although the fact is that the error is not repeated and sometimes we are having a successful build. BUILD FAILED C:\opt\jenkins\workspace\Lightyear Trunk\label\dev-relbld2\trunk\build.xml:1270: The following error occurred while executing this line: C:\opt\jenkins\workspace\Lightyear Trunk\label\dev-relbld2\trunk\build.xml:1522: The following error occurred while executing this line: C:\opt\jenkins\workspace\Lightyear Trunk\label\dev-relbld2\trunk\build.xml:1596: You must not specify more than one attribute when using refid when I looked into the build.xml at line 1596 below is the tag. I checked that all the three attributes are the valid one for PCTRun tag. So can anyone help me to debug this error that what may be the cause of this error. Thanks & Regards Ajay Dhyani
