Dave Wright
Hi - I am trying to surface various Oracle Service Cloud custom objects/tables through OData. We have numerous custom objects in our instance of OSvC that are divided across several 'packages'/schemas. Using the 'select schema' dropdown list within the DataDairect Cloud OData 'configure schema' editor, I can only seem to select tables/objects from one OScV 'package' at a time. Each time I switch between one schema/package and another it resets my config. Is it possible to achieve this using the UI editor or will I have to create/edit a JSON schema manually? Thanks, David
