[progress Communities] [progress Openedge Abl] Forum Post: Urgent Request For Help...
  • Thread starter Thread starter Dan Johansen
Dan Johansen
Hi - we have an issue in upgrading between versions of the databases, and are hoping for any assistance or insight. We have an old Progress 7 database that is being upgrade to the latest version. We are able to upgrade that DB from 7 to 8, but it routinely fails when upgrading from 8-9. We have seen it succeed a couple of times, but that involves a lot of varying factors that we have not been able to identify. Instead of using the convert scripts, we are directly running the _proutil commands manually to try and isolate the problem. Specifically, "91_proutil.exe db_name -C conv89" The error is mvGetRecord(drPopulateTable): failed with -1 (7065). Also, we are running on Windows Server 2008 R2 (64-bit), but have also tried 32-bit versions. I'm currently re-installing the 32-bit version to try again that way. Any suggestions or help? Thank you!!
