[Progress Communities] [Progress OpenEdge ABL] Forum Post: System.Reflection.AmbiguousMatchException: Ambiguous match found.
  • Thread starter Thread starter oedev
O
oedev
Progress 10.2B08 3rd party library: RestSharp - Simple REST and HTTP Client for .NET Using a version of the library built for .NET 3.5 ( https://github.com/bnoffer/owncloud-sharp/files/527037/RestSharp.zip ) --- When making a simple request using the library, I'm receiving the following error; "System.Reflection.AmbiguousMatchException: Ambiguous match found." This occurs when using any of the execute methods provided on the RestClient. Stacktrace of error; NET StackTrace: --> at System.DefaultBinder.SelectMethod(BindingFlags bindingAttr, MethodBase[] match, Type[] types, ParameterModifier[] modifiers) at Progress.ClrBridge.UnknownBinder.SelectMethod(BindingFlags bindingAttr, MethodBase[] match, Type[] types, ParameterModifier[] modifiers) at System.RuntimeType.GetMethodImpl(String name, BindingFlags bindingAttr, Binder binder, CallingConventions callConv, Type[] types, ParameterModifier[] modifiers) at System.Type.GetMethod(String name, BindingFlags bindingAttr, Binder binder, Type[] types, ParameterModifier[] modifiers) at Progress.ClrBridge.ClrApi.InvokeMethod(Object instance, String typeName, String methodName, Type[] types, Object[] args) at Progress.ClrBridge.BrgClrFromPro.invokeMethod(BrgClrFromPro* , Int32 , SByte* , SByte* , Int32 , prmhdr* , Int32* , Int32 ) Any pointers to what the cause may be? Using this library as need to do a mult-form submission with form fields and a file, and using the standard .NET HTTP client is quite onerous. Thanks.
