[progress Communities] [progress Openedge Abl] Forum Post: Source Management Solution :...
  • Thread starter Thread starter bulletproof
B
bulletproof
Hi, I would like to know which tools exists to manage Progress source codes for an application, and which software/solution are you using ? Especially about : - Source code technical impact analysis coverage on source code ; - Packaging tool ; - Deployment tool ; - Build tool ; - Repository (SVN) ; - Development validation workflow tool ; - etc. And how to integrate all these tools together ? More specifically, how to address these kind of issues : - packaging management / technical impact => eg. : I deploy 10 programs, somebody else deploy 5 programs, how to detect the links / dependencies /impact ? (avoid mismatch parameters errors when a program’s parameters are modified but not the other ones who called it) ; - best practices to manage an huge number of source codes objects (over 10 000) ; - tool to detect technical impact related to source code dependencies . What I would like to know is especially if there are some "standard solution" and / or already existing product on the market to achieve these actions for a Progress application. If you have anything from what you use in your company or what you know (even if you use in-house tooling), please let me know. Thanks in advance
