Sanjeva Manchala
Hi Sivarami Reddy, ABLUnit results are always generated with name results.xml in the current working directory. If there is an already existing results.xml, it'll be overridden. I think you can append results manually, but we never tried from our side. As long as the results.xml file format is inline with ABLUnit results.xml, PDS OE can display that file in Results view. If you want to see the results of previous run, you can see them from PDSOE's ABLUnit view (Under Test Run History toolbar menu item). Thanks, Sanjeev
