[progress Communities] [progress Openedge Abl] Forum Post: Re: When/why Does Abl Client...
  • Thread starter Thread starter ChUIMonster
C
ChUIMonster
In my case I was more focused on how I could possibly avoid causing the problem for others. It seems like the meta-schema and VST' definitions are not going to change (you have to use proutil -C update* for that) and so, logically, references to those might reasonably be exempt. But I guess the decision was very "all or nothing" and so even those objects trigger the schema lock.
