[Progress Communities] [Progress OpenEdge ABL] Forum Post: RE: What is the maximum possible value of -io for a probkup incremental?
  • Thread starter Thread starter George Potemkin
George Potemkin
> we're using OE 11.5. I'll need to check the more recent versions. The issue # 20041203-030 is fixed in 9.1E01/10.0B02: "Online backup performance problem has been fixed. The fix requires that the -Bp parameteris used. The minimal of -Bp 10 will suffice." The same fix also eliminated the eviction of the buffers when probkup is not use -Bp. Tests with 11.7: "Used buffers" when probkup (without -Bp) is waiting on proquiet'ed sports database is 33. "Used buffers" when backup complete is changed to: Used buffers: 33 -> 45 -Bp 0 43 -Bp 10 107 -Bp 100 After dbanalys: Used buffers: 1057 Danalys: 1073 total blocks found in the database.
